Saltar al contenido principal
Introducción
The alarm unit is located behind the glove box. Once the glovebox is out of the way, you can remove the black plastic alarm unit, open it and change the dip switch for a less sensitive setting.
Partes
No se especificaron partes.
  1. Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. It may be stubborn to get out because it is stuck down with double stick foam pads.
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  4. Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  5. Turn the board over and locate the 2 position dip switch.
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
Conclusión
3 personas más completaron esta guía.
mpeeples
Miembro Desde 04/04/10
184 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 1,875
