Saltar al contenido principal
Adjusting Right/Left Speaker Balance
  1. Adjusting Right/Left Speaker Balance, Adjusting Right/Left Speaker Balance: paso 1, imagen 1 de 1
    • The balance knob is the rightmost knob on the front panel.
  2. Adjusting Right/Left Speaker Balance: paso 2, imagen 1 de 2 Adjusting Right/Left Speaker Balance: paso 2, imagen 2 de 2
    • Turning the balance knob to the right increases the sound played by the right speaker.
    • Turning the knob left will increase the sound played by the left speaker.
  3. Adjusting Right/Left Speaker Balance: paso 3, imagen 1 de 2 Adjusting Right/Left Speaker Balance: paso 3, imagen 2 de 2
    • Turning the knob all the way to the right will make the right speaker play all the sound.
    • Turning the knob all the way to the left will make the left speaker play all the sound.
  4. Adjusting Right/Left Speaker Balance: paso 4, imagen 1 de 1
    • The default position is center, which should play the sound equally by both speakers.
    • If this position does not play the sound equally by both speakers, experiment with different knob positions until the speakers play the sound equally.
Linea de Meta
Jan Vazquez
Miembro Desde 04/09/10
239 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 27-92, Amido Spring 2010 Miembro de Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Miembros
7 Guías creadas
Un comentario
Finally, I can die in peace
john goor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 5,722
