Saltar al contenido principal
Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet
  1. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet, Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: paso 1, imagen 1 de 1
    • Before starting the repair, make sure that the device is unplugged and the water reservoir is empty.
    • Detach the water reservoir from the brewer by lifting the reservoir vertically from the device.
  2. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: paso 2, imagen 1 de 2 Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: paso 2, imagen 2 de 2
    • The magnet is located in the bottom of the reservoir.
    • Remove the grey lid from the top of the reservoir.
    • Insert your hand and manually realign the magnet to where it slides freely in its enclosed area.
Conclusión
2 personas más completaron esta guía.
Alexander Vo
Miembro Desde 01/11/13
94 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-2, Maness Winter 2013 Miembro de Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 57
Todo El Tiempo: 20,039
