Saltar al contenido principal
Adjusting Contrast on TI-Nspire Calculator
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: paso 1, imagen 1 de 2 Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: paso 1, imagen 2 de 2
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. Adjusting Contrast on TI-Nspire Calculator: paso 2, imagen 1 de 3 Adjusting Contrast on TI-Nspire Calculator: paso 2, imagen 2 de 3 Adjusting Contrast on TI-Nspire Calculator: paso 2, imagen 3 de 3
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
Conclusión
Now you should have the image contrast set to your preferences.
Una persona más ha completado esta guía.
Alan Wong
Miembro Desde 09/26/12
63 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-52, Forte Fall 2012 Miembro de Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 5,935
