Saltar al contenido principal
Adjust the Action (String Height) on Ibanez SR405QM
Qué necesitas
  1. Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: paso 1, imagen 1 de 2 Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: paso 1, imagen 2 de 2
    • Pay attention to the distance between both the fretboard and pickups.
    • Test the strings by plucking and take note of which ones are difficult to play or are producing an unpleasant metallic sound.
  2. Adjust the Action (String Height) on Ibanez SR405QM: paso 2, imagen 1 de 2 Adjust the Action (String Height) on Ibanez SR405QM: paso 2, imagen 2 de 2
    • Using a 2 mm Allen Key turn the corresponding string's screw clockwise to raise the string and counterclockwise to lower the string.
    • The screw is located on the bridge of the guitar next to its corresponding string.
    • While modifying a strings height try plucking the string and listening to the sound produced until at desired sound.
Linea de Meta
Una persona más ha completado esta guía.
Chris Pittner
Miembro Desde 01/11/13
220 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-18, Forte Winter 2013 Miembro de Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 23
Ultimos 30 días: 92
Todo El Tiempo: 6,155
