Saltar al contenido principal
AcuRite 02032 Wind Cup Assembly Replacement
Qué necesitas
  1. AcuRite 02032 Wind Cup Assembly Replacement, Battery: paso 1, imagen 1 de 3 AcuRite 02032 Wind Cup Assembly Replacement, Battery: paso 1, imagen 2 de 3 AcuRite 02032 Wind Cup Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery compartment lid by lifting upward.
  2. AcuRite 02032 Wind Cup Assembly Replacement: paso 2, imagen 1 de 1
    • Pull the ribbon to eject the 2 X AA alkaline batteries.
  3. AcuRite 02032 Wind Cup Assembly Replacement: paso 3, imagen 1 de 3 AcuRite 02032 Wind Cup Assembly Replacement: paso 3, imagen 2 de 3 AcuRite 02032 Wind Cup Assembly Replacement: paso 3, imagen 3 de 3
    • Once the batteries are removed, it is safe to proceed.
  4. AcuRite 02032 Wind Cup Assembly Replacement, Base: paso 4, imagen 1 de 1
    • Remove the four 0.8cm screws that attach the bottom panel to the device
    • An extended driver is needed to reach 3 of these screws. If you are using the 64 - bit driver kit you can extend the driver by inserting the driver PH1, (Phillips size 1) into the size 4 hexagonal adapter.
  5. AcuRite 02032 Wind Cup Assembly Replacement: paso 5, imagen 1 de 2 AcuRite 02032 Wind Cup Assembly Replacement: paso 5, imagen 2 de 2
    • Gently lift the top section of the weather center away from the base. With all the screws removed it should lift off easily.
  6. AcuRite 02032 Wind Cup Assembly Replacement, Wind Cup Assembly: paso 6, imagen 1 de 1
    • Remove the four 0.8cm screws inside the case located near the fan using the J1 screw bit.
  7. AcuRite 02032 Wind Cup Assembly Replacement: paso 7, imagen 1 de 2 AcuRite 02032 Wind Cup Assembly Replacement: paso 7, imagen 2 de 2
    • With all four screws removed, the wind cup assembly should lift straight up off the middle section.
    • Set down the bottom half of the weather center careful. There are two small pegs that will break with the slightest amount of pressure.
  8. AcuRite 02032 Wind Cup Assembly Replacement: paso 8, imagen 1 de 1
    • Replace the old wind cup assembly with the new assembly that was purchased.
Conclusión
Ben Kegel
Miembro Desde 09/15/16
350 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 1-4, Bruce Fall 2016 Miembro de CSU Fullerton, Team 1-4, Bruce Fall 2016
CSUF-BRUCE-F16S1G4
5 Miembros
7 Guías creadas
3 comentarios
Do you have to replace the whole top, wind cups,top plate with solar panel, just for the wind cups?
Tom Halverson - Contestar
For a broken wind cups do you have to replace the top section with the solar panel?
No. After you take it apart hold the shaft turn broken cup assy off. Install new cups in reverse order.
Larry Lindsay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 1,605
