Saltar al contenido principal
Acrylic Nail Tip Replacement
Qué necesitas
  1. Acrylic Nail Tip Replacement, Acrylic Nail Tip: paso 1, imagen 1 de 1
    • File the nail in a back-and-forth motion with the nail file on the accessible part of the natural nail until it is no longer smooth.
    • Try not to file the acrylic nail that is is still attached to your natural nail, as it will not fit the part that broke.
  2. Acrylic Nail Tip Replacement: paso 2, imagen 1 de 1
    • Carefully place a drop of nail glue on the natural nail and let the glue sit for about 5 seconds.
    • Do not use more than 1-2 drops of nail glue.
  3. Acrylic Nail Tip Replacement: paso 3, imagen 1 de 2 Acrylic Nail Tip Replacement: paso 3, imagen 2 de 2
    • Place a nail tip in its original position and hold it in place for about 20 seconds, or until it is fully dry.
  4. Acrylic Nail Tip Replacement: paso 4, imagen 1 de 2 Acrylic Nail Tip Replacement: paso 4, imagen 2 de 2
    • Pour 30 milliliters of monomer in a small glass bowl.
    • Liquid nail monomer has a strong odor and is highly flammable.
    • Do not reuse the glass bowl for any food products because of possible chemical residue.
  5. Acrylic Nail Tip Replacement: paso 5, imagen 1 de 3 Acrylic Nail Tip Replacement: paso 5, imagen 2 de 3 Acrylic Nail Tip Replacement: paso 5, imagen 3 de 3
    • Dip the brush in the monomer and lightly tap it on the paper towel to remove the excess.
  6. Acrylic Nail Tip Replacement: paso 6, imagen 1 de 2 Acrylic Nail Tip Replacement: paso 6, imagen 2 de 2
    • Place the tip of the brush in clear acrylic powder at about an 80-degree angle; collect it on one side of the brush.
  7. Acrylic Nail Tip Replacement: paso 7, imagen 1 de 3 Acrylic Nail Tip Replacement: paso 7, imagen 2 de 3 Acrylic Nail Tip Replacement: paso 7, imagen 3 de 3
    • Apply the acrylic powder to the nail, and in a dabbing, downward motion, smooth the acrylic over the nail from top to bottom.
  8. Acrylic Nail Tip Replacement: paso 8, imagen 1 de 1
    • Place the nail under the UV/LED lamp until hard and firm.
  9. Acrylic Nail Tip Replacement: paso 9, imagen 1 de 3 Acrylic Nail Tip Replacement: paso 9, imagen 2 de 3 Acrylic Nail Tip Replacement: paso 9, imagen 3 de 3
    • Use a nail drill to file the nail to achieve an even acrylic coat by drilling in a side-to-side motion, working your way from top to bottom.
    • Use a speed of 7-9 on the nail drill.
    • If you do not have a nail drill, you can also use a nail file.
  10. Acrylic Nail Tip Replacement: paso 10, imagen 1 de 3 Acrylic Nail Tip Replacement: paso 10, imagen 2 de 3 Acrylic Nail Tip Replacement: paso 10, imagen 3 de 3
    • Buff the nail until it is smooth, and use a paper towel to wipe off excess powder.
  11. Acrylic Nail Tip Replacement: paso 11, imagen 1 de 3 Acrylic Nail Tip Replacement: paso 11, imagen 2 de 3 Acrylic Nail Tip Replacement: paso 11, imagen 3 de 3
    • Optional: coat the nail with clear polish.
Linea de Meta
Alysia Williams
Miembro Desde 02/28/22
194 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 255
