Saltar al contenido principal
Acer Travelmate 220 RAM Replacement
Qué necesitas
  1. Acer Travelmate 220 RAM Replacement, RAM Chip: paso 1, imagen 1 de 1
    • Place the computer with the bottom facing up.
  2. Acer Travelmate 220 RAM Replacement: paso 2, imagen 1 de 3 Acer Travelmate 220 RAM Replacement: paso 2, imagen 2 de 3 Acer Travelmate 220 RAM Replacement: paso 2, imagen 3 de 3
    • Locate the larger cover panel in the upper left hand corner of the computer.
    • Locate the Phillips screw holding the large cover panel in place.
  3. Acer Travelmate 220 RAM Replacement: paso 3, imagen 1 de 2 Acer Travelmate 220 RAM Replacement: paso 3, imagen 2 de 2
    • Remove the located screw with the Phillips #00 screwdriver.
  4. Acer Travelmate 220 RAM Replacement: paso 4, imagen 1 de 1
    • Slide the large cover panel to the right, until you hear a click.
  5. Acer Travelmate 220 RAM Replacement: paso 5, imagen 1 de 2 Acer Travelmate 220 RAM Replacement: paso 5, imagen 2 de 2
    • Place the plastic opening tool in the gap created to the left of the large cover panel.
    • Pry the cover panel up and remove it from the computer.
  6. Acer Travelmate 220 RAM Replacement: paso 6, imagen 1 de 2 Acer Travelmate 220 RAM Replacement: paso 6, imagen 2 de 2
    • Locate the white plastic levers on each side of the two RAM chips.
  7. Acer Travelmate 220 RAM Replacement: paso 7, imagen 1 de 3 Acer Travelmate 220 RAM Replacement: paso 7, imagen 2 de 3 Acer Travelmate 220 RAM Replacement: paso 7, imagen 3 de 3
    • Locate the first RAM chip.
    • Push the plastic levers away from the first RAM chip.
  8. Acer Travelmate 220 RAM Replacement: paso 8, imagen 1 de 3 Acer Travelmate 220 RAM Replacement: paso 8, imagen 2 de 3 Acer Travelmate 220 RAM Replacement: paso 8, imagen 3 de 3
    • Lift the RAM chip from the compartment.
    • Repeat steps 7 and 8 to replace the second RAM chip.
Conclusión
2 personas más completaron esta guía.
Kevin A
Miembro Desde 10/04/11
55 Reputación
1 Guía escrita
Equipo
UW Stout, Team 5-5, Zhou Fall 2011 Miembro de UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 3,356
