Saltar al contenido principal
Introducción
How to replace optical drive for Acer Travelmate 220 due to malfunctioning disk drive. Symptoms are drive does not read disks, does not respond to inserted disks, or if there are multiple disk drive errors.
Partes
No se especificaron partes.
  1. Flip your computer over so the bottom case is facing you.
    • Flip your computer over so the bottom case is facing you.
  2. Locate the sliding unlock button near the AC power input.
    • Locate the sliding unlock button near the AC power input.
  3. Slide the button in the direction of unlock and hold.
    • Slide the button in the direction of unlock and hold.
  4. Gently pull the disk drive out.
    • Gently pull the disk drive out.
  5. Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver. Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver. Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
    • Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
  6. Remove the black plastic that covers the metal. Remove the black plastic that covers the metal.
    • Remove the black plastic that covers the metal.
  7. Locate the green chip on the back of the drive.
    • Locate the green chip on the back of the drive.
  8. Remove the two screws securing the green chip. Remove the two screws securing the green chip.
    • Remove the two screws securing the green chip.
  9. Firmly pull off the green chip.
    • Firmly pull off the green chip.
  10. Insert the green chip in the new disk drive.
    • Insert the green chip in the new disk drive.
Conclusión
Una persona más ha completado esta guía.
Justin
Miembro Desde 04/10/11
62 Reputación
1 Guía escrita
Equipo
UW Stout, Team 5-5, Zhou Fall 2011 Miembro de UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 Miembros
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 4,344
