Saltar al contenido principal
Acer TravelMate TMB115-M-C99B Touchpad Replacement
Qué necesitas
  1. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 2, imagen 1 de 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 2, imagen 2 de 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 2, imagen 3 de 3
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 3, imagen 1 de 1
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 4, imagen 1 de 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 4, imagen 2 de 2
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: paso 5, imagen 1 de 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: paso 5, imagen 2 de 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: paso 5, imagen 3 de 3
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Motherboard: paso 6, imagen 1 de 1
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 7, imagen 1 de 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 7, imagen 2 de 2
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 8, imagen 1 de 1
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 9, imagen 1 de 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 9, imagen 2 de 2
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 10, imagen 1 de 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 10, imagen 2 de 2
    • Remove the motherboard.
  11. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Touchpad: paso 11, imagen 1 de 1
    • Remove one 6mm Phillips screw from the middle of the touchpad with the #0 screwdriver.
  12. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 12, imagen 1 de 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 12, imagen 2 de 2
    • Remove the wire from the slot.
  13. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 13, imagen 1 de 1
    • Remove the stickers from the touchpad frame.
  14. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 14, imagen 1 de 1
    • Remove one 6mm screw from the corner of the touchpad frame with the #0 screwdriver.
  15. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 15, imagen 1 de 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 15, imagen 2 de 2
    • Lift up the touchpad frame.
  16. Acer TravelMate TMB115-M-C99B Touchpad Replacement: paso 16, imagen 1 de 1
    • Remove the touchpad.
Conclusión
Tanvi Kharkar
Miembro Desde 01/24/19
334 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S1-G5, White Winter 2019 Miembro de Cal Poly, Team S1-G5, White Winter 2019
CPSU-WHITE-W19S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 490
