Saltar al contenido principal
Acer TravelMate P653-V-6882 RAM Replacement
Qué necesitas
  1. Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: paso 1, imagen 1 de 2 Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: paso 1, imagen 2 de 2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 RAM Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 RAM Replacement: paso 3, imagen 1 de 1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 RAM Replacement, Base Door: paso 4, imagen 1 de 1
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 RAM Replacement: paso 5, imagen 1 de 1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 RAM Replacement: paso 6, imagen 1 de 2 Acer TravelMate P653-V-6882 RAM Replacement: paso 6, imagen 2 de 2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Acer TravelMate P653-V-6882 RAM Replacement, RAM: paso 7, imagen 1 de 1
    • Locate the two RAM sticks on the bottom of the laptop.
  8. Acer TravelMate P653-V-6882 RAM Replacement: paso 8, imagen 1 de 3 Acer TravelMate P653-V-6882 RAM Replacement: paso 8, imagen 2 de 3 Acer TravelMate P653-V-6882 RAM Replacement: paso 8, imagen 3 de 3
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
Conclusión
Basel Kandil
Miembro Desde 01/18/20
85 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 238
