Introducción
If you need to swap out a faulty Optical Disc Drive (ODD) Module on the Acer TravelMate P653-V-6882, or if you’re simply disassembling the TravelMate, you must remove the ODD module.
Here is a guide on how to replace the Acer TravelMate P653-V-6882 ODD module.
Turn the computer over so the base is facing up.
Slide the battery lock to unlock position.
Casi Terminas!
Conclusión
