Saltar al contenido principal
Acer TravelMate P653-V-6882 Mainboard Replacement
Qué necesitas
  1. Acer TravelMate P653-V-6882 Mainboard Replacement, Battery Pack: paso 1, imagen 1 de 2 Acer TravelMate P653-V-6882 Mainboard Replacement, Battery Pack: paso 1, imagen 2 de 2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 3, imagen 1 de 1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 Mainboard Replacement, ODD Module: paso 4, imagen 1 de 1
    • Slide the ODD module latch down.
    • The ODD module will pop out.
  5. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 5, imagen 1 de 1
    • Remove the ODD module.
  6. Acer TravelMate P653-V-6882 Mainboard Replacement, Base Door: paso 6, imagen 1 de 1
    • Remove the five 7mm Phillips #1 screws.
  7. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 7, imagen 1 de 1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  8. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 8, imagen 1 de 2 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 8, imagen 2 de 2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  9. Acer TravelMate P653-V-6882 Mainboard Replacement, RAM: paso 9, imagen 1 de 1
    • Locate the two RAM sticks on the bottom of the laptop.
  10. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 10, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 10, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 10, imagen 3 de 3
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
  11. Acer TravelMate P653-V-6882 Mainboard Replacement, Keyboard: paso 11, imagen 1 de 1
    • Remove the two 7mm Phillips #1 screws.
  12. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 12, imagen 1 de 1
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  13. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 13, imagen 1 de 1
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  14. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 14, imagen 1 de 1
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
  15. Acer TravelMate P653-V-6882 Mainboard Replacement, Mainboard: paso 15, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement, Mainboard: paso 15, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement, Mainboard: paso 15, imagen 3 de 3
    • Turn the computer over, open the LCD panel, and find the smart card cable connector.
    • Open the smart card cable connector latch.
    • Disconnect the cable.
  16. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 16, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 16, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 16, imagen 3 de 3
    • Find the power button launch board cable connector.
    • Open the power button launch board cable connector latch.
  17. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 17, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 17, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 17, imagen 3 de 3
    • Find the touchpad and fingerprint board cable connector.
    • Open the touchpad and fingerprint board cable connector’s latches.
    • Disconnect the cables.
  18. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 18, imagen 1 de 1
    • Using the #1 Phillips screwdriver, remove the two screws.
  19. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 19, imagen 1 de 1
    • Flip the laptop over so that the underside is facing up.
    • Remove the twelve 7mm Phillips #1 screws.
    • Remove the five 3mm Phillips #1 screws.
    • Disconnect the cables connecting to the WLAN module.
  20. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 20, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 20, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 20, imagen 3 de 3
    • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
    • Insert the opening tool into each gap to separate the one from the other.
    • Once the upper cover is separated, lift it from the lower case.
    • Be careful not to damage the upper and lower case while removing.
  21. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 21, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 21, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 21, imagen 3 de 3
    • Detach the transparent tape securing the LCD cable.
    • Disconnect the LCD cable from the mainboard.
    • Be careful not to damage the LCD cable connector.
  22. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 22, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 22, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 22, imagen 3 de 3
    • Detach the black tape covering the microphone cable.
    • Disconnect the microphone cable from the mainboard.
  23. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 23, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 23, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 23, imagen 3 de 3
    • Open the USB board cable's connector latches.
    • Be careful not to damage the connectors.
  24. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 24, imagen 1 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 24, imagen 2 de 3 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 24, imagen 3 de 3
    • Disconnect the left speaker cable from the mainboard.
  25. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 25, imagen 1 de 1
    • Remove the one 7mm Phillips #1 screw.
  26. Acer TravelMate P653-V-6882 Mainboard Replacement: paso 26, imagen 1 de 2 Acer TravelMate P653-V-6882 Mainboard Replacement: paso 26, imagen 2 de 2
    • Lift the mainboard at an angle and gently turn it on its side.
    • Disconnect the LAN cable from the mainboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 490
