Saltar al contenido principal
Acer Swift X N20C12 Trackpad Replacement
Qué necesitas
  1. Acer Swift X N20C12 Trackpad Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Trackpad Replacement: paso 2, imagen 1 de 1
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Trackpad Replacement, Battery: paso 3, imagen 1 de 1
    • Grasp the battery connector and pull it directly out of its socket.
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws that secure the battery.
  4. Acer Swift X N20C12 Trackpad Replacement: paso 4, imagen 1 de 1
    • Lift the battery up and out of the chassis.
  5. Acer Swift X N20C12 Trackpad Replacement, Trackpad: paso 5, imagen 1 de 1
    • Use a Phillips # 1 screwdriver to remove the 2.9 mm screws that secure the trackpad.
    • Disconnect the trackpad connector.
  6. Acer Swift X N20C12 Trackpad Replacement: paso 6, imagen 1 de 1
    • Lift the trackpad up and out of the chassis.
Conclusión
Abrar
Miembro Desde 09/08/23
471 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-2, Pee Fall 2023 Miembro de Gateway, Team 1-2, Pee Fall 2023
GCC-PEE-F23S1G2
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 106
