Saltar al contenido principal
Acer Spin 7 SP714-51 Battery Replacement
Qué necesitas
  1. Acer Spin 7 SP714-51 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Battery Replacement: paso 2, imagen 1 de 1
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
  3. Acer Spin 7 SP714-51 Battery Replacement: paso 3, imagen 1 de 2 Acer Spin 7 SP714-51 Battery Replacement: paso 3, imagen 2 de 2
    • Remove the battery connector cable from the motherboard.
    • This will cut power to the laptop, reducing the likelihood of damage and injury.
    • Ensure that you are pulling the connector straight back, if you pull up at all you may damage the battery connector on the motherboard.
  4. Acer Spin 7 SP714-51 Battery Replacement: paso 4, imagen 1 de 2 Acer Spin 7 SP714-51 Battery Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the last two 3mm long fasteners at the edge of the laptop body, and carefully remove the battery.
    • Place the new battery in the battery slot
    • Do not bend or puncture the battery.
Conclusión
Zach Desrosiers
Miembro Desde 03/22/22
565 Reputación
5 Guías creadas
Equipo
2 comentarios
The connector can be plugged in two different ways: RED wires to the left or to the right. Which is correct?
William Barrett - Contestar
As pictured, I believe it is red wires to the left when orienting the laptop with the battery slot closest to you. However, this was for a technical communications project I and others wrote some time ago for college, and as such I no longer have access to the laptop so I cannot confirm for sure. Let me know if you have any other questions, I’d be happy to help out if I can.
- Zach D
Zach Desrosiers -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 50
Todo El Tiempo: 949
