Saltar al contenido principal
Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement
Qué necesitas
  1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: paso 1, imagen 1 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: paso 1, imagen 2 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 2, imagen 1 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 2, imagen 2 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 2, imagen 3 de 3
    • Remove the piece of black tape that covers the battery.
  3. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 3, imagen 1 de 2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 3, imagen 2 de 2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  4. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 4, imagen 1 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 4, imagen 2 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 4, imagen 3 de 3
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  5. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 5, imagen 1 de 2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 5, imagen 2 de 2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  6. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: paso 6, imagen 1 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: paso 6, imagen 2 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: paso 6, imagen 3 de 3
    Comprar
    • Using tweezers, remove the sticker that covers the connection between the wireless card and motherboard.
  7. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 7, imagen 1 de 2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 7, imagen 2 de 2
    • Remove the 6.5 mm screw that secures the wireless card using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 8, imagen 1 de 2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 8, imagen 2 de 2
    • Gently pull the wireless card away from the motherboard.
  9. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 9, imagen 1 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 9, imagen 2 de 3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 9, imagen 3 de 3
    • Using your fingers, carefully pull the white wire upwards, removing it from the terminal of the wireless card.
  10. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 10, imagen 1 de 2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 10, imagen 2 de 2
    • Repeat the previous step but this time for the black wire.
  11. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 11, imagen 1 de 2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: paso 11, imagen 2 de 2
    • Remove the wireless (WiFi) card from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 1,554
