Saltar al contenido principal
Acer Spin 3 SP315-51-79NT Touch Screen Replacement
Qué necesitas
  1. Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Back Panel: paso 1, imagen 1 de 2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Back Panel: paso 1, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
  2. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 2, imagen 1 de 2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 2, imagen 2 de 2
    • Gently pry the back plate off with your fingers.
  3. Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Screen Assembly: paso 3, imagen 1 de 2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Screen Assembly: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove a total of four screws from the hinges (two on each hinge).
  4. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 4, imagen 1 de 2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 4, imagen 2 de 2
    • Remove wires connecting to motherboard.
    • You can then simply pull the two halves of the computer away from each other.
  5. Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Touch Screen: paso 5, imagen 1 de 2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Touch Screen: paso 5, imagen 2 de 2
    • Use a spudger to separate the plastic cover from the screen assembly.
    • Do not use a metal spudger for this step. The metal spudger should only be used for serious prying power. When used incorrectly, the metal spudger can cause serious damage to the internal components (especially glass) in the device.
  6. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 6, imagen 1 de 2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 6, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the four screws securing the touch screen to the rest of the assembly.
  7. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: paso 7, imagen 1 de 1
    • Flip over the touch screen to reveal the circuit board.
    • Disconnect the cable from the circuit board and completely remove the touch screen from the device.
Conclusión
3 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 2-1, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 42
Todo El Tiempo: 1,897
