Saltar al contenido principal
Acer Spin 3 SP315-51-757C Hard Drive Replacement
Qué necesitas
  1. Acer Spin 3 SP315-51-757C Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 2 Acer Spin 3 SP315-51-757C Hard Drive Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 2, imagen 1 de 3 Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 2, imagen 2 de 3 Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 2, imagen 3 de 3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 3, imagen 1 de 1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Acer Spin 3 SP315-51-757C Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Loosen the single Phillips #0 screw holding the hard drive in place.
  5. Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 5, imagen 1 de 2 Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 5, imagen 2 de 2
    • Gently lift the closer side of the hard drive out of its slot.
    • Make sure not to pull too hard on the cables plugged into the motherboard.
  6. Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 6, imagen 1 de 1
    • Carefully unplug the cable connected to the side of the hard drive.
  7. Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 7, imagen 1 de 2 Acer Spin 3 SP315-51-757C Hard Drive Replacement: paso 7, imagen 2 de 2
    • Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
Conclusión
2 personas más completaron esta guía.
2Guía Comentarios
Awesome. Thanks for the tips here. Do you have any recommendations on what SSD may go with Acer Spin 3 SP315-51-757C ? I am a little clue less here since i am new to this, and any feedback here would help. Thanks.
S B - Contestar
I just replaced my HDD with a 1TB Crucial MX500 SSD. It was easy to clone the drive and simple to install. My computer went from almost unusable to better than new, I highly recommend it.
Adam Kahler -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 51
Todo El Tiempo: 4,663
