Saltar al contenido principal
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
Qué necesitas
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: paso 1, imagen 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: paso 1, imagen 2 de 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: paso 2, imagen 1 de 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: paso 2, imagen 2 de 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: paso 2, imagen 3 de 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: paso 3, imagen 1 de 1
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: paso 4, imagen 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: paso 5, imagen 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: paso 5, imagen 2 de 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: paso 6, imagen 1 de 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: paso 7, imagen 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: paso 7, imagen 2 de 2
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: paso 8, imagen 1 de 1
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
Conclusión
2 personas más completaron esta guía.
Jeffrey Kong
Miembro Desde 09/22/14
809 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-3, Forte Fall 2014 Miembro de Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 2,792
