Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement
Qué necesitas
  1. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Bottom Case: paso 1, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Bottom Case: paso 1, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Bottom Case: paso 1, imagen 3 de 3
    • Turn off the laptop by holding down the power button for 7 seconds.
    • Verify that the blue power indicator light is turned off.
    Pregunta a FixBot
    Agregar Comentario
  2. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 2, imagen 1 de 2 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 2, imagen 2 de 2
    • Remove the plug from the back of your laptop.
    • Verify that the charging light is off after you remove the plug.
    • The battery’s charging light turns “amber” when plugged into the power cord and charging. The indicator light switches to blue once the battery is fully charged.
    Pregunta a FixBot
    Agregar Comentario
  3. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 3, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 3, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 3, imagen 3 de 3
    • Remove the eleven screws from the bottom case with a Phillips #1 Screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  4. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 4, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 4, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Spudger
    $3.99
    • A spudger is a tool that can help separate electronic panels without scratching or damaging your device.
    • Use your thumb to apply gentle upward pressure on the laptop vent while using a spudger to separate the bottom case from the top case.
    • Work the spudger along the seam where the bottom case meets the top case.
    • Apply gentle upward pressure on the opposite laptop vent as you work the spudger across the back of the laptop.
    Pregunta a FixBot
    Agregar Comentario
  5. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 5, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 5, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 5, imagen 3 de 3
    • Turn the laptop so the laptop vents are facing away from you and the bottom case remains face up.
    • Use your fingertips to pull gently upward on the vents while using your palms to apply gentle downward pressure on the bottom case.
    • Move your hands outward from the center of the laptop to each side, continuing to pull the bottom case gently upward with your fingertips.
    • Lift the bottom case away from the laptop.
    Pregunta a FixBot
    Agregar Comentario
  6. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Battery: paso 6, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Battery: paso 6, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, Battery: paso 6, imagen 3 de 3
    • Always consider protecting against electrostatic discharge (ESD) when working on the components inside your laptop.
    • A properly grounded ESD mat and wristband can protect your laptop from ESD damage.
    • Remove the two screws securing the battery to the top case with a Phillips #0 Screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  7. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 7, imagen 1 de 1
    • Lift the battery up and away from the motherboard to expose its connection wire.
    Pregunta a FixBot
    Agregar Comentario
  8. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 8, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 8, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 8, imagen 3 de 3
    • Gently remove the connection wire from the motherboard using a spudger.
    • Remove the cable only a little at a time from each side, as shown in the photos. This avoids damaging the connections.
    • Lift the disconnected battery out of the laptop.
    Pregunta a FixBot
    Agregar Comentario
  9. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, PCIe Solid State Drive (SSD): paso 9, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, PCIe Solid State Drive (SSD): paso 9, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement, PCIe Solid State Drive (SSD): paso 9, imagen 3 de 3
    • Unscrew the retaining screw that secures the SSD to the motherboard with a Phillips #0 screwdriver.
    • Ensure you are wearing a properly grounded ESD wristband before handling your SSD.
    • Gently pull your SSD out of the motherboard's PCIe slot.
    • Store your SSD on your properly grounded ESD mat while it is outside of your laptop.
    Pregunta a FixBot
    Agregar Comentario
  10. Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 10, imagen 1 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 10, imagen 2 de 3 Acer Predator Helios 300 PH315-53 PCIe Solid State Drive (SSD) Replacement: paso 10, imagen 3 de 3
    • Repeat the actions you performed in the previous step to remove the SSD that is on the other side of your motherboard.
    • This slot will be empty if you have not previously upgraded your storage with an additional SSD.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Documentos Adjuntos
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 14
Ultimos 30 días: 84
Todo El Tiempo: 1,445
