Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Acer Predator Helios 300 Battery Replacement
Qué necesitas
  1. Acer Predator Helios 300 Battery Replacement, Battery: paso 1, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement, Battery: paso 1, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Before you start make sure the laptop is grounded.
    • Make sure the laptop is powered off.
    • If the laptop is not turned off, there is a risk of electric shock when replacing the battery.
    • Close the cover of the laptop, then turn the laptop upside down so the back is facing up.
    Pregunta a FixBot
    Agregar Comentario
  2. Acer Predator Helios 300 Battery Replacement: paso 2, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement: paso 2, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement: paso 2, imagen 3 de 3
    • Remove all the screws from the back panel with a Phillips #0 screwdriver.
    • Remove the hard drive screw using a Phillips #0 screwdriver.
    • Use the panel tool to pop the storage hard disk open.
    Pregunta a FixBot
    Agregar Comentario
  3. Acer Predator Helios 300 Battery Replacement: paso 3, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement: paso 3, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement: paso 3, imagen 3 de 3
    • Remove the four screws mounted near the storage hard disk using a Phillips #0 screwdriver.
    • Disconnect the cable connected to the storage hard disk.
    Pregunta a FixBot
    Agregar Comentario
  4. Acer Predator Helios 300 Battery Replacement: paso 4, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement: paso 4, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement: paso 4, imagen 3 de 3
    • Use the panel tool to remove the back cover.
    • Slowly open the clips attached to the back cover, and store the cover safely.
    Pregunta a FixBot
    Agregar Comentario
  5. Acer Predator Helios 300 Battery Replacement: paso 5, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement: paso 5, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the tape holding the battery wires in.
    • Remove the two screws mounted next to the battery using a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard slowly.
    • Remove the old battery.
    Pregunta a FixBot
    Agregar Comentario
  6. Acer Predator Helios 300 Battery Replacement: paso 6, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement: paso 6, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement: paso 6, imagen 3 de 3
    • The battery is a Household Hazardous Waste, so be sure to follow your city's laws and dispose of them properly.
    • Connect the new battery connector to the motherboard and screw it back with the screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  7. Acer Predator Helios 300 Battery Replacement: paso 7, imagen 1 de 2 Acer Predator Helios 300 Battery Replacement: paso 7, imagen 2 de 2
    • Align the back cover with the laptop properly and click it with all the clips.
    Pregunta a FixBot
    Agregar Comentario
  8. Acer Predator Helios 300 Battery Replacement: paso 8, imagen 1 de 3 Acer Predator Helios 300 Battery Replacement: paso 8, imagen 2 de 3 Acer Predator Helios 300 Battery Replacement: paso 8, imagen 3 de 3
    • Insert the storage disk back in.
    • Connect it with the cable first and then fit it inside the missing space.
    • Fasten the remaining screws using a screwdriver.
    Pregunta a FixBot
    Agregar Comentario
Linea de Meta
3 personas más completaron esta guía.
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 60
Ultimos 30 días: 217
Todo El Tiempo: 5,620
