Saltar al contenido principal
Acer One 10 S1003-19GY WiFi Antenna Replacement
Qué necesitas
  1. Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: paso 1, imagen 1 de 2 Acer One 10 S1003-19GY WiFi Antenna Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY WiFi Antenna Replacement: paso 2, imagen 1 de 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: paso 3, imagen 1 de 3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: paso 3, imagen 2 de 3 Acer One 10 S1003-19GY WiFi Antenna Replacement, WiFi Antenna: paso 3, imagen 3 de 3
    • Disconnect the black ribbon connection attached to the motherboard.
    • Remove the chip fully by pulling the plastic tab on the left out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 680
