Saltar al contenido principal
Acer One 10 S1003-19GY Rear/Front Camera Replacement
Qué necesitas
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: paso 1, imagen 1 de 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 2, imagen 1 de 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: paso 3, imagen 1 de 1
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 4, imagen 1 de 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 4, imagen 2 de 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 4, imagen 3 de 3
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 5, imagen 1 de 1
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 6, imagen 1 de 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement: paso 6, imagen 2 de 2
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 353
