Saltar al contenido principal
Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair
Qué necesitas
  1. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: paso 1, imagen 1 de 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: paso 1, imagen 2 de 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: paso 2, imagen 1 de 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: paso 3, imagen 1 de 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: paso 3, imagen 2 de 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: paso 3, imagen 3 de 3
    • Flip the latch and carefully pull the ribbon free.
  4. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: paso 4, imagen 1 de 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: paso 4, imagen 2 de 2
    • Remove the two screws holding the dock in place using a Phillips #0 screwdriver.
    • Pull the dock out and slide it out of the device.
Conclusión
Un comentario
dove acquistare questo connettore :Acer ONE 10 (S1003 D16H1) Docking Port Connector Cable, grazie . francescomar25@gmail.com
Francesco - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,250
