Saltar al contenido principal
Acer One 10 S1003-19GY Battery Replacement
Qué necesitas
  1. Acer One 10 S1003-19GY Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Acer One 10 S1003-19GY Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Battery Replacement: paso 2, imagen 1 de 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Battery Replacement, Battery: paso 3, imagen 1 de 3 Acer One 10 S1003-19GY Battery Replacement, Battery: paso 3, imagen 2 de 3 Acer One 10 S1003-19GY Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Remove the two pieces of transparent yellow tape inside the device.
    • Using the Phillips #0 screwdriver, remove the two screws on either side of the connector.
    • Grab the the connector with tweezers and pull it slightly away from the motherboard.
  4. Acer One 10 S1003-19GY Battery Replacement: paso 4, imagen 1 de 2 Acer One 10 S1003-19GY Battery Replacement: paso 4, imagen 2 de 2
    • Flip the small black latch up on the connector where the ribbon inserts.
    • Gently pull the ribbon out of the connection.
    • Repeat this process on the upper orange ribbon connection.
  5. Acer One 10 S1003-19GY Battery Replacement: paso 5, imagen 1 de 2 Acer One 10 S1003-19GY Battery Replacement: paso 5, imagen 2 de 2
    • Peel back the black tape holding the battery in the three corners of the battery.
  6. Acer One 10 S1003-19GY Battery Replacement: paso 6, imagen 1 de 2 Acer One 10 S1003-19GY Battery Replacement: paso 6, imagen 2 de 2
    • Carefully pry the battery off of the adhesive on one side with a plastic spudger.
    • Remove the battery from the device.
    • We recommend to NOT use a metal spudger for this guide as a metal spudger can easily puncture lithium-ion batteries and cause further damage to yourself and the device.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Does anyone know where I can get a replacement battery and ship it to EU? Sadly, this Laptop doesnt turn on without the battery.
Nico V - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 28
Todo El Tiempo: 1,288
