Saltar al contenido principal
Acer One 10 S1003-114M Track Pad Replacement
Qué necesitas
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: paso 1, imagen 1 de 1
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: paso 2, imagen 1 de 1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: paso 3, imagen 1 de 2 Acer One 10 S1003-114M Track Pad Replacement: paso 3, imagen 2 de 2
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: paso 4, imagen 1 de 3 Acer One 10 S1003-114M Track Pad Replacement: paso 4, imagen 2 de 3 Acer One 10 S1003-114M Track Pad Replacement: paso 4, imagen 3 de 3
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: paso 5, imagen 1 de 1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: paso 6, imagen 1 de 1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: paso 7, imagen 1 de 1
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: paso 8, imagen 1 de 2 Acer One 10 S1003-114M Track Pad Replacement: paso 8, imagen 2 de 2
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: paso 9, imagen 1 de 2 Acer One 10 S1003-114M Track Pad Replacement: paso 9, imagen 2 de 2
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: paso 10, imagen 1 de 3 Acer One 10 S1003-114M Track Pad Replacement: paso 10, imagen 2 de 3 Acer One 10 S1003-114M Track Pad Replacement: paso 10, imagen 3 de 3
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: paso 11, imagen 1 de 1
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: paso 12, imagen 1 de 1
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: paso 13, imagen 1 de 1
    • Gently remove the trackpad from the keyboard.
Conclusión
Karan Karthik
Miembro Desde 04/01/19
217 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G6, Harley Spring 2019 Miembro de IUPUI, Team S2-G6, Harley Spring 2019
IUPUI-HARLEY-S19S2G6
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 730
