Saltar al contenido principal
Acer One 10 S1003-114M Key Replacement
Qué necesitas
  1. Acer One 10 S1003-114M Key Replacement, Key: paso 1, imagen 1 de 2 Acer One 10 S1003-114M Key Replacement, Key: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Make sure your device is powered off and disconnected from any power supply.
    • Open the laptop and disconnect the tablet screen from the magnetic keyboard dock by gently lifting the screen up.
    • Use tweezers to gently pry up the damaged key.
  2. Acer One 10 S1003-114M Key Replacement: paso 2, imagen 1 de 1
    • White plastic springs may become misaligned when removing key.
    • If the plastic springs do become misaligned, use tweezers to realign springs by popping them back into their horizontal placement.
Conclusión
Un comentario
Is there any place we can buy replacement keys?
Nur Ahmad Furlong - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 33
Todo El Tiempo: 3,117
