Saltar al contenido principal
Acer One 10 S1002 145-A Screen Replacement
Qué necesitas
  1. Acer One 10 S1002 145-A Screen Replacement, Motherboard: paso 1, imagen 1 de 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Screen Replacement: paso 2, imagen 1 de 2 Acer One 10 S1002 145-A Screen Replacement: paso 2, imagen 2 de 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Screen Replacement: paso 3, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 3, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 3, imagen 3 de 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Screen Replacement: paso 4, imagen 1 de 2 Acer One 10 S1002 145-A Screen Replacement: paso 4, imagen 2 de 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Screen Replacement: paso 5, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 5, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 5, imagen 3 de 3
  6. Acer One 10 S1002 145-A Screen Replacement: paso 6, imagen 1 de 2 Acer One 10 S1002 145-A Screen Replacement: paso 6, imagen 2 de 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Screen Replacement: paso 7, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 7, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 7, imagen 3 de 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Screen Replacement: paso 8, imagen 1 de 1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Screen Replacement, Battery: paso 9, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement, Battery: paso 9, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement, Battery: paso 9, imagen 3 de 3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
  10. Acer One 10 S1002 145-A Screen Replacement, Camera: paso 10, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement, Camera: paso 10, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement, Camera: paso 10, imagen 3 de 3
    • Separate the adhesive cable from the underlying copper ribbon cable.
    • Gently pry off the camera from from tablet backing.
    • Remove the camera and set it aside.
  11. Acer One 10 S1002 145-A Screen Replacement, Screen: paso 11, imagen 1 de 2 Acer One 10 S1002 145-A Screen Replacement, Screen: paso 11, imagen 2 de 2
    • Open the latch on the copper connector and remove it from the tablet.
  12. Acer One 10 S1002 145-A Screen Replacement: paso 12, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 12, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 12, imagen 3 de 3
    • Remove the three 3.5mm screws from the outside perimeter of the tablet.
  13. Acer One 10 S1002 145-A Screen Replacement: paso 13, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 13, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 13, imagen 3 de 3
    • Remove the three small latches that are underneath the screws.
  14. Acer One 10 S1002 145-A Screen Replacement: paso 14, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 14, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 14, imagen 3 de 3
    • Peel the silver tape on the side of the tablet using the nylon spudger. Do not completely remove the tape.
    • Peel the gold tape gently. Do not completely remove the tape.
  15. Acer One 10 S1002 145-A Screen Replacement: paso 15, imagen 1 de 2 Acer One 10 S1002 145-A Screen Replacement: paso 15, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Locate the small green connector with the black cable attached.
    • Disconnect the black cable from the small green connector using the precision tweezers.
  16. Acer One 10 S1002 145-A Screen Replacement: paso 16, imagen 1 de 1
    iOpener
    $12.99
    Comprar
    • Use a heating pack (iOpener), a hair dryer, or heat gun, and place it over the highlighted glue areas.
    • This will heat up the glue beneath the tape in order to separate the LCD from the screen.
  17. Acer One 10 S1002 145-A Screen Replacement: paso 17, imagen 1 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 17, imagen 2 de 3 Acer One 10 S1002 145-A Screen Replacement: paso 17, imagen 3 de 3
    • Using the nylon spudger, gently pry the LCD from the screen.
    • Once separated, gently lift away the LCD from the screen.
    • Place tablet screen to the side.
Conclusión
3 personas más completaron esta guía.
Shannon Griffin
Miembro Desde 10/03/16
1,372 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-3, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 9,339
