Saltar al contenido principal
Acer Nitro AN515-55 RAM Replacement
Qué necesitas
  1. Acer Nitro AN515-55 RAM Replacement, RAM: paso 1, imagen 1 de 2 Acer Nitro AN515-55 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Shut off the computer and unplug any sources of power, including the charger.
    • Unplug any other devices that may be plugged into the computer.
  2. Acer Nitro AN515-55 RAM Replacement: paso 2, imagen 1 de 2 Acer Nitro AN515-55 RAM Replacement: paso 2, imagen 2 de 2
    • Remove eleven screws from the back of the laptop using a Phillips #0 screwdriver.
  3. Acer Nitro AN515-55 RAM Replacement: paso 3, imagen 1 de 1
    • Slide a plastic opening pick between the rear panel and laptop body to remove the rear panel.
    • Using a metal prying tool to open up the rear panel of your computer may damage the plastic case.
  4. Acer Nitro AN515-55 RAM Replacement: paso 4, imagen 1 de 2 Acer Nitro AN515-55 RAM Replacement: paso 4, imagen 2 de 2
    • Using your fingers, disconnect the battery pin by pulling back on the two tabs located at the ends of the pin.
    • You do not need to take the entire battery out, just the pin.
    • Make sure you have grounded yourself before touching any of your computer's components.
  5. Acer Nitro AN515-55 RAM Replacement: paso 5, imagen 1 de 2 Acer Nitro AN515-55 RAM Replacement: paso 5, imagen 2 de 2
    • Slide the RAM stick into the RAM slot at about a 45 degree angle.
    • Push the RAM stick down until you hear a click.
    • You do need to apply a bit of pressure when pushing down on the RAM.
  6. Acer Nitro AN515-55 RAM Replacement: paso 6, imagen 1 de 1
    • Reconnect the battery pin by reinserting the connector back into its slot.
  7. Acer Nitro AN515-55 RAM Replacement: paso 7, imagen 1 de 1
    • Place the rear panel back on the computer.
    • Screw the panel back in.
    • You may need to push down on the panel to lock the panel back in.
Conclusión
Once your rear panel is properly put back on, check if your RAM has been installed correctly. Power on your computer. This may take longer than usual because the computer is identifying the new piece of hardware. After your computer has booted up, go to About System (Settings > System > About). Under the “Installed RAM” portion of the page, you will see the amount of RAM your computer has installed. If this amount is correct, you have successfully installed your RAM.
4 personas más completaron esta guía.
Samir Patel
Miembro Desde 09/10/21
279 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 1,228
