Introducción
The touchpad is a quality of life component for laptops. It helps the user to quickly and efficiently operate the cursor. A touchpad does not improve performance of a laptop.
Replacing the Acer Nitro 5 AN517-51-56YW touchpad can be quick and easy. All that is needed is a Phillips head screwdriver (Size: PH1) and a touchpad replacement part. Follow the guide for step-by-step instructions on replacing the touchpad.
Qué necesitas
Place the laptop upside-down so that the fans are facing away from you.
Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
Pry the bottom cover away from the laptop using a spudger.
Unplug the connection plug that attaches the battery to the motherboard.
Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
Lift the adhesive ribbon to be able to remove the touchpad.
