Saltar al contenido principal
Acer Nitro 5 AN517-51-56YW Touch Pad Replacement
Qué necesitas
  1. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: paso 1, imagen 1 de 3 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: paso 1, imagen 2 de 3 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: paso 2, imagen 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: paso 2, imagen 2 de 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
  4. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: paso 4, imagen 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: paso 4, imagen 2 de 2
    • Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
    • Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
    • Lift the adhesive ribbon to be able to remove the touchpad.
    • Do not remove the ribbon completely, only the part that is on the touchpad.
  5. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: paso 5, imagen 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: paso 5, imagen 2 de 2
    • Lift the touchpad towards you from the bottom.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 260
