Saltar al contenido principal
Acer Nitro 5 AN517-51-56YW Battery Replacement
Qué necesitas
  1. Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: paso 1, imagen 1 de 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: paso 1, imagen 2 de 3 Acer Nitro 5 AN517-51-56YW Battery Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: paso 2, imagen 1 de 2 Acer Nitro 5 AN517-51-56YW Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Battery Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN517-51-56YW Battery Replacement: paso 3, imagen 2 de 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 52
Todo El Tiempo: 1,585
