Saltar al contenido principal
Acer Nitro 5 AN515-57 RAM Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: paso 1, imagen 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: paso 2, imagen 1 de 1
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement: paso 3, imagen 2 de 2
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: paso 4, imagen 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: paso 5, imagen 1 de 3 Acer Nitro 5 AN515-57 RAM Replacement: paso 5, imagen 2 de 3 Acer Nitro 5 AN515-57 RAM Replacement: paso 5, imagen 3 de 3
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: paso 6, imagen 1 de 1
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: paso 7, imagen 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement: paso 7, imagen 2 de 2
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
Linea de Meta
Una persona más ha completado esta guía.
Hanzala Mir
Miembro Desde 01/17/22
170 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 34
Ultimos 30 días: 134
Todo El Tiempo: 4,391
