Qué necesitas
Make sure the device is off and unplugged from power.
Flip the device so the bottom is facing up.
Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
Disconnect the seven cables from the motherboard using an iFixit opening tool.
Unplug the two fan connectors from each side of the motherboard using an opening tool.
2 personas más completaron esta guía.
