Saltar al contenido principal
Acer Nitro 5 AN515-55-55M1 Battery Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Battery Replacement: paso 2, imagen 1 de 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: paso 3, imagen 1 de 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: paso 3, imagen 2 de 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Battery Replacement: paso 4, imagen 1 de 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
Conclusión
Congratulations! You have successfully replaced the battery of your Acer Nitro 5 AN515-55-55M1!
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 43
Ultimos 30 días: 209
Todo El Tiempo: 10,948
