Saltar al contenido principal
Acer Nitro 5 AN515-55-53AG Internal Fan Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Prior to beginning, be sure to turn off the device and unplug it from the power source.
    • Set the device on a flat surface with the vents facing upwards.
  2. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 2, imagen 1 de 2 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 2, imagen 2 de 2
    • Use your Phillips #0 screwdriver to remove the eleven screws holding down the laptop's bottom cover.
  3. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 3, imagen 1 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 3, imagen 2 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Remove the laptop's bottom cover using an opening tool or plastic card.
    • Do not use a metal tool during this process. Doing so would risk damaging both the cover and the electrical components.
    • Be gentle during removal. Do not force the cover off, or it may break.
  4. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 4, imagen 1 de 2 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 4, imagen 2 de 2
    • Detach the fan's wire connector from the motherboard.
  5. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 5, imagen 1 de 1
    • Peel up the two strips of black tape holding the fan.
    • Do not peel the tape all the way off. Leave the tape attached to the heatsink.
  6. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 6, imagen 1 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 6, imagen 2 de 3 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 6, imagen 3 de 3
    • Remove the two screws holding the fan in place using a Phillips #0 screwdriver.
    • Remove the old fan by pulling it directly up.
  7. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 7, imagen 1 de 2 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: paso 7, imagen 2 de 2
    • While the fan is out, clean the space with a cloth or a can of compressed air. Clean the fan vents and plate of any dust.
Conclusión
2 personas más completaron esta guía.
Un comentario
на an515-55-534c система охлаждения так же разбирается ? или это он и есть ?
Антон Хабаров - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 23
Ultimos 30 días: 92
Todo El Tiempo: 6,098
