Saltar al contenido principal
Acer Nitro 5 AN515-55 SSD Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-55 SSD Replacement, SSD: paso 1, imagen 1 de 1
    • Shut down your laptop.
    • Make sure your laptop is completely turned off to prevent damaging other parts.
  2. Acer Nitro 5 AN515-55 SSD Replacement: paso 2, imagen 1 de 3 Acer Nitro 5 AN515-55 SSD Replacement: paso 2, imagen 2 de 3 Acer Nitro 5 AN515-55 SSD Replacement: paso 2, imagen 3 de 3
    • Flip the laptop on its back.
    • Remove the eleven 8 mm screws securing the back cover using the Phillips #1 screwdriver.
  3. Acer Nitro 5 AN515-55 SSD Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: paso 3, imagen 2 de 2
    • Loosen the back cover using a plastic opening tool.
  4. Acer Nitro 5 AN515-55 SSD Replacement: paso 4, imagen 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: paso 4, imagen 2 de 2
    • Pull the back cover off and put it in a safe place.
    • A little bit of force is needed to pry open the clips at the corners of the laptop.
  5. Acer Nitro 5 AN515-55 SSD Replacement: paso 5, imagen 1 de 3 Acer Nitro 5 AN515-55 SSD Replacement: paso 5, imagen 2 de 3 Acer Nitro 5 AN515-55 SSD Replacement: paso 5, imagen 3 de 3
    • Remove the 2.6 mm screw that is holding down the SSD with a Phillips #0 screwdriver.
    • Make sure to ground yourself before working on the motherboard to prevent damage.
  6. Acer Nitro 5 AN515-55 SSD Replacement: paso 6, imagen 1 de 3 Acer Nitro 5 AN515-55 SSD Replacement: paso 6, imagen 2 de 3 Acer Nitro 5 AN515-55 SSD Replacement: paso 6, imagen 3 de 3
    • Gently pull out the damaged SSD.
  7. Acer Nitro 5 AN515-55 SSD Replacement: paso 7, imagen 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: paso 7, imagen 2 de 2
    • Slide in the new SSD.
    • Screw it in place.
  8. Acer Nitro 5 AN515-55 SSD Replacement: paso 8, imagen 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: paso 8, imagen 2 de 2
    • Put the back cover on and gently snap the clips back in.
    • Screw the back cover in place.
Conclusión
Follow the guide that comes with your new SSD to make sure your laptop recognizes your new SSD.
5 personas más completaron esta guía.
Un comentario
This model is supposed to have 3 slots 2 for SSD and 1 for HDD, can you please point them out? Just add an extra SDD?
mayumidb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 33
Ultimos 30 días: 148
Todo El Tiempo: 8,080
