Saltar al contenido principal
Introducción
Use this guide to replace the SSD in the Acer Nitro 5 Acer Nitro 5 AN515-53-55G9. This laptop comes with a SSD installed, this guide will show how to replace an new SSD.
  1. Make sure  laptop is off and unplugged before beginning replacement. Flip  the laptop upside down so that the bottom is facing up. Identify the RAM tray on the bottom of the laptop.
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering. Remove the RAM tray cover by prying up with a spudger. Remove the RAM tray cover by prying up with a spudger.
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Identify the Hard Drive tray to the left side of the laptop. Remove screw with a #0 Philips screwdriver. Lift up the Slot covering using a spunger.
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
  5. Carefully remove the back shell from the device working your way around all the edges. Do not forcefully try to separate the shell as you may cause harm to the shell. Do not forcefully try to separate the shell as you may cause harm to the shell.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Removing the back shell of the computer and it will look like this. The battery for the device is located at the bottom middle of the laptop at this orientation.
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Locate the connector of the battery to the motherboard. Using your fingers, slide out the connector. Using your fingers, slide out the connector.
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Remove battery from device.
    • Remove battery from device.
  9. Locate the SSD in the top right corner of the laptop. Locate the SSD in the top right corner of the laptop.
    • Locate the SSD in the top right corner of the laptop.
  10. Use the Phillips #0 screwdriver to remove the 3mm screw holding the SSD card in place. The SSD will pop up an an angle when the screw is removed. The SSD will pop up an an angle when the screw is removed.
    • Use the Phillips #0 screwdriver to remove the 3mm screw holding the SSD card in place.
    • The SSD will pop up an an angle when the screw is removed.
  11. Slide the SSD out of its slot.
    • Slide the SSD out of its slot.
Conclusión
8 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 56
Ultimos 30 días: 284
Todo El Tiempo: 8,404
