Saltar al contenido principal
Acer Nitro 5 AN515-53-55G9 Battery Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: paso 1, imagen 1 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: paso 1, imagen 2 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 2, imagen 1 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 2, imagen 2 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 2, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 3, imagen 1 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 3, imagen 2 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 3, imagen 3 de 3
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 5, imagen 1 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 5, imagen 2 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 5, imagen 3 de 3
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 6, imagen 1 de 2 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 6, imagen 2 de 2
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 7, imagen 1 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 7, imagen 2 de 3 Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 7, imagen 3 de 3
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 Battery Replacement: paso 8, imagen 1 de 1
    • Remove battery from device.
Conclusión
11 personas más completaron esta guía.
3 comentarios
For future articles, you might consider adding a section describing how to “initialize” the replacement battery pack to maximize life.
Either that, or at least mention initialization plays a part in maximizing battery life and point to another article that provides reliable information.
Thanks for the article.
jmagecko - Contestar
And how do you put it back in? Cause it’s a pain in the ass to put back in easy to take out pain in the &&^&^$^ ass to put back in
Mally02 - Contestar
After I put the new battery the battery indicator doesn't stop flashing orange? any ideas?
Dido - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 75
Ultimos 30 días: 335
Todo El Tiempo: 38,818
