Saltar al contenido principal
Acer Nitro 5 AN515-53-52FA CMOS Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-53-52FA CMOS Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 2, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 3, imagen 2 de 2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 5, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 6, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 6, imagen 2 de 2
    • Lift the battery up and out of the laptop.
  7. Acer Nitro 5 AN515-53-52FA CMOS Replacement, CMOS: paso 7, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement, CMOS: paso 7, imagen 2 de 2
    • Locate the CMOS that is under the battery.
  8. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 8, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 8, imagen 2 de 2
    • Gently unplug the port.
  9. Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 9, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA CMOS Replacement: paso 9, imagen 2 de 2
    • Carefully pull the CMOS Battery, as there is adhesive keeping it attached.
Conclusión
Alfredo Prieto
Miembro Desde 09/01/22
827 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2022 Miembro de Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 61
Ultimos 30 días: 337
Todo El Tiempo: 5,157
