Saltar al contenido principal
Acer Nitro 5 AN515-53-52FA Battery Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 2, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 3, imagen 2 de 2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 5, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 6, imagen 1 de 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: paso 6, imagen 2 de 2
    • Lift the battery up and out of the laptop.
Conclusión
Una persona más ha completado esta guía.
Alfredo Prieto
Miembro Desde 09/01/22
827 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2022 Miembro de Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Miembros
7 Guías creadas
2 comentarios
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Contestar
Can I use a Jimmy instead of the opening picks?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 33
Ultimos 30 días: 140
Todo El Tiempo: 1,139
