Saltar al contenido principal
Acer Nitro 5 AN515-44-R70B Fan Replacement
Qué necesitas
  1. Acer Nitro 5 AN515-44-R70B Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Make sure the laptop is off and unplugged before beginning the fan replacement
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 2, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the eleven M2.5x6.0 size screws holding the back cover in place.
  3. Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 3, imagen 1 de 2 Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 3, imagen 2 de 2
    • Carefully remove the back shell from the device.
    • Do not be too forceful as you could damage the shell.
  4. Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 4, imagen 1 de 1
    • For extra caution slide out the battery cable from its connector using your fingers.
  5. Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 5, imagen 1 de 1
    • Using your fingers, slide out the two fan cables from their connectors.
  6. Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 6, imagen 1 de 2 Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 6, imagen 2 de 2
    • Remove the gaffer tape next to the fan.
  7. Acer Nitro 5 AN515-44-R70B Fan Replacement: paso 7, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the four M2.5x6.0 size screws holding the fan assembly in place.
    • You can now remove the old fans and replace them with new ones.
Conclusión
Ilyass Sellouf
Miembro Desde 01/15/24
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 68
Todo El Tiempo: 225
