Saltar al contenido principal
Acer Iconia W3-810 Speaker Replacement
Qué necesitas
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: paso 4, imagen 1 de 1
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: paso 5, imagen 1 de 1
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: paso 7, imagen 1 de 1
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: paso 8, imagen 1 de 1
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: paso 9, imagen 1 de 1
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: paso 10, imagen 1 de 1
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: paso 11, imagen 1 de 1
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: paso 12, imagen 1 de 1
    • Remove the speakers from the device.
Conclusión
Griffin Hocker
Miembro Desde 09/15/16
394 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 18-4, Blackwell Fall 2016 Miembro de USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 410
