Saltar al contenido principal
Acer Iconia W3-810 Rear-Facing Camera Replacement
Qué necesitas
  1. Acer Iconia W3-810 Rear-Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Rear-Facing Camera Replacement: paso 2, imagen 1 de 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 3, imagen 1 de 1
    • Lift the retaining flap fastening the ribbon cord to the motherboard using a plastic opening tool.
  4. Acer Iconia W3-810 Rear-Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the ribbon cord from its slot using a plastic opening tool.
  5. Acer Iconia W3-810 Rear-Facing Camera Replacement: paso 5, imagen 1 de 1
    • Remove the rear-facing camera from its slot and pose for a camera shot.
Conclusión
Adam Fierce
Miembro Desde 09/15/16
418 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 18-4, Blackwell Fall 2016 Miembro de USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 463
