Saltar al contenido principal
Acer Iconia Tab A501 Wireless Adapter Replacement
Qué necesitas
  1. Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Wireless Adapter Replacement: paso 2, imagen 1 de 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: paso 3, imagen 1 de 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: paso 3, imagen 2 de 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    Comprar
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Wireless Adapter Replacement: paso 4, imagen 1 de 1
    • Remove all tape covering the wireless adapter.
  5. Acer Iconia Tab A501 Wireless Adapter Replacement: paso 5, imagen 1 de 3 Acer Iconia Tab A501 Wireless Adapter Replacement: paso 5, imagen 2 de 3 Acer Iconia Tab A501 Wireless Adapter Replacement: paso 5, imagen 3 de 3
    • Use the flat end of the standard Spudger to disconnect the two small rotatable connectors attached to the wireless adapter.
  6. Acer Iconia Tab A501 Wireless Adapter Replacement: paso 6, imagen 1 de 2 Acer Iconia Tab A501 Wireless Adapter Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
  7. Acer Iconia Tab A501 Wireless Adapter Replacement: paso 7, imagen 1 de 2 Acer Iconia Tab A501 Wireless Adapter Replacement: paso 7, imagen 2 de 2
    • Carefully slide the adapter out to remove it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 347
