Saltar al contenido principal
Acer Iconia Tab A501 Docking Port Replacement
Qué necesitas
  1. Acer Iconia Tab A501 Docking Port Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Iconia Tab A501 Docking Port Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Iconia Tab A501 Docking Port Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Docking Port Replacement: paso 2, imagen 1 de 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Docking Port Replacement, Docking Port: paso 3, imagen 1 de 3 Acer Iconia Tab A501 Docking Port Replacement, Docking Port: paso 3, imagen 2 de 3 Acer Iconia Tab A501 Docking Port Replacement, Docking Port: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Docking Port Replacement: paso 4, imagen 1 de 3 Acer Iconia Tab A501 Docking Port Replacement: paso 4, imagen 2 de 3 Acer Iconia Tab A501 Docking Port Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to flip up the locking mechanism for the ribbon cable on the docking port board that is flat, white, and folded.
    • Detach the folded, white ribbon cable on the docking port board.
  5. Acer Iconia Tab A501 Docking Port Replacement: paso 5, imagen 1 de 2 Acer Iconia Tab A501 Docking Port Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
  6. Acer Iconia Tab A501 Docking Port Replacement: paso 6, imagen 1 de 2 Acer Iconia Tab A501 Docking Port Replacement: paso 6, imagen 2 de 2
    • Remove the docking port.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 189
