Saltar al contenido principal
Acer Iconia Tab A501 Back Cover Replacement
Qué necesitas
  1. Acer Iconia Tab A501 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Acer Iconia Tab A501 Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Acer Iconia Tab A501 Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Back Cover Replacement: paso 2, imagen 1 de 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 203
