Saltar al contenido principal
Acer Iconia Tab A200 DC Power Jack Component Replacement
Qué necesitas
  1. Acer Iconia Tab A200 DC Power Jack Component Replacement, Battery: paso 1, imagen 1 de 2 Acer Iconia Tab A200 DC Power Jack Component Replacement, Battery: paso 1, imagen 2 de 2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 2, imagen 1 de 2 Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 3, imagen 1 de 2 Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 3, imagen 2 de 2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 4, imagen 1 de 2 Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 5, imagen 1 de 2 Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 5, imagen 2 de 2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
  6. Acer Iconia Tab A200 DC Power Jack Component Replacement, DC Power Jack Component: paso 6, imagen 1 de 1
    • Using the plastic opening tool gently lift up the charging component out of its slot in the case.
  7. Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 7, imagen 1 de 1
    • Continue to lift up the cord until it is free from the case and only attached to the motherboard.
    • You may need to continue using the plastic opening tool to lift the cord out of the case due to limited hand space.
  8. Acer Iconia Tab A200 DC Power Jack Component Replacement: paso 8, imagen 1 de 1
    • Disconnect the power component from the motherboard by pulling it out horizontally. Do not pull up on the cord only pull out
Conclusión
3 personas más completaron esta guía.
Jaimie Payne
Miembro Desde 03/06/16
477 Reputación
3 Guías creadas
Equipo
2 comentarios
Probably no need to REPLACE the jack. Just push the little indented tabs in a fraction of a millimeter and it will make good contact again. I just did this with mine and it works perfectly now after having been a royal PITA for over a year.
hammondkeys - Contestar
Will this work if I bought a charger that either charges inside the tip connected to the prong, or thru the outer side of the plug. I used the wrong setting and now I only see the green robot on his side. It won't boot
karen p - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 1,385
