Saltar al contenido principal
Acer Iconia Tab A200 Battery Replacement
Qué necesitas
  1. Acer Iconia Tab A200 Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Iconia Tab A200 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Battery Replacement: paso 2, imagen 1 de 2 Acer Iconia Tab A200 Battery Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Battery Replacement: paso 3, imagen 1 de 2 Acer Iconia Tab A200 Battery Replacement: paso 3, imagen 2 de 2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Battery Replacement: paso 4, imagen 1 de 2 Acer Iconia Tab A200 Battery Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Battery Replacement: paso 5, imagen 1 de 2 Acer Iconia Tab A200 Battery Replacement: paso 5, imagen 2 de 2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
Conclusión
Una persona más ha completado esta guía.
Jaimie Payne
Miembro Desde 03/06/16
477 Reputación
3 Guías creadas
Equipo
2 comentarios
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
Michael Burlovich - Contestar
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
Gloria Regester - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,797
