Qué necesitas
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
Use tweezers or the flat end of the spudger to carefully pull the connection loose.
Casi Terminas!
Conclusión
